CHÀO ANH EM, SAU KHI THAM KHẢO KHÁ NHIỀU TRÊN DIỂN ĐÀN THÌ MÌNH CŨNG THÍCH TỰ CHẾ CHO EM EXC CỦA MÌNH 1 BỘ PASSING. MÌNH THẤY CÓ RẤT NHIỀU HƯỚNG DẪN NHƯNG HƠI KHÓ HIỂU VÀ HƠI KHÓ ĐỂ DÁM THỬ THỰC HIỆN NÊN MÌNH VIẾT BÀI NÀY ĐỂ HƯỚNG DẪN VÀ CÁCH MÌNH LÀM RÕ HƠN. CÁCH NÀY SỬ DỤNG RELAY NÊN CÓ THỂ SỰ DỤNG CHO XE ĐANG SỬ DỤNG ĐIỆN MÁY/BÌNH MÀ KHÔNG ẢNH HƯỜNG ĐẾN DÀNG ĐIỆN TRÊN XE NHÉ, KHÔNG CHẠM CHẬP/ SỬ DỤNG LÂU DÀI. ---------------------------------- ** LINH KIỆN CẦN TÌM: + 1 CÔNG TẮC ĐỀ WAVE 110 :GIÁ 20- 30K HÀNG HONDA. + 1 CỤC RELAY (RƠ LE) 12V 5A (LOẠI 5A TRỞ LÊN): GIÁ 5 -10K NHẬT TẢO NHIỀU. + 1 CÔNG TẮC GIỮ ON/OFF TÙY BẠN CHỌN: NHẬT TẢO NHIỀU. ** DỤNG CỤ CẦN CÓ: + 1 CÂY HÀNG CHÌ/ DÂY CHÌ + 3M DÂY ĐIỆN ĐÔI 1.5 + 1 CUỘN BĂNG KEO ĐIỆN + 1 CÂY SÚNG BẮNG KEO NÓNG. + 1 DAO RỌC GIẤY/ DÂY RÚT 15CM/... NGOÀI RA CẦN DỤNG CỤ THÁO XE VÀ KỸ TAY 1 CHÚT. ----------------- OK SƠ LƯỢT TA CÓ SƠ ĐỒ CẦN THỰC HIỆN NHƯ THẾ NÀY: BẮT TAY VÀO CHƠI THÔI. ĐOẠN ĐẦU LÀ THÁO BỘ CHÓA ĐÈN, ĐỤT LỔ, HÀN CÔNG TẮC ĐỀ VÀ ĐƯA VÀO VỊ TRÍ, KỸ TAY 1 CHÚT BẠN SẼ CÓ VỊ TRÍ VÀ CÔNG TẮC ĐỆP. TIẾP ĐỀN LÀ CHƠI VỚI CỤC RELAY: HÀN DÂY TRƯỚC, BẠN NHỚ CANH DÂY DÀI 1 CHÚT ĐỂ KHI RÁP VÀO CÓ THỂ CẮT BỚT ĐI ĐƯỢC OK XONG PHẦN CÔNG TẮC ------------- TIẾP THEO MANG XUỐNG RÁP VÔ XE THÔI. VỊ TRÍ DÂY MÁT VÀ DÂY CHÂN SỐ 4 LẤY NGUỒN TỪ ĐIỆN BÌNH TRÊN RELAY. LÊN XE, NỐI DÂY VÀ TEST TRƯỚC SAU ĐÓ MỚI CẮT DÂY VÀ BUỘC DÂY KĨ LẠI NHA MÁY BẠN. MÌNH ĐÃ TEST OK VÀ RÚT DÂY LẠI. CỤC RELAY MÌNH BÓ LẠI TRONG BỌC NILON VÀ RÚT LẠI ĐỂ TRÁNH NƯỚC. OK. XONG. PHẦN NÀY MÌNH KHÔNG CÓ BƯỚC LẮP CÔNG TẮC ON/OFF, CÔNG TẮC NÀY CÁC BẠN CHỌN VỊ TRÍ TÙY CHỈNH RỒI LÀM NHÉ, NÓ RẤT ĐƠN GIẢN. CLIP TEST TRÊN XE MÌNH.
